I'm running Ubuntu 14.04 and I have some troubles with Vim editor. First I was using the normal version preinstalled with Ubuntu, then I installed VI Improved from Ubuntu Software Center, with some plugins for working with Python.
Everything was fine until I installed GVim again from Ubuntu Software Center. I liked that version because it has a menu bar, I can launch GVim from the Unity dock, etc. Then I uninstall VI Improved from Ubuntu Software Center because I thought it didn't has sense to have it installed, I also move usr/share/vim folder to my home folder because I thought that was the folder containing GVim files (the one I wanted to use) and almost every plugins are installed in that path.
I really really screwed up, I installed and reinstalled, erased and restored files and Vim packages looking for the solution, now when I open GVim, it doesn't show the menu bar, the highlighting doesn't work too, I try to run :Explore command and it gives me E492 error (It is not an editor order: Explore), also the autocomplete is not working.
What do you guys recommend me? I want GVim working right again with my vim folder to install plugins, and .vimrc file to customize it. Thank you.
Xweque
  • 1,103
You can try reinstalling GVim:
sudo apt-get install --reinstall vim-gnome vim-gui-common vim-common vim-runtime
In particular, I think you need the *-common and *-runtime package files.
muru
  • 207,228
