I tried the following but I get the errors at the end. In order to make sure that 4.8.2 was not interfering, I removed it.
Any suggestions would be great!
sudo add-apt-repository ppa:ubuntu-toolchain-r/test
sudo apt-get update
sudo apt-get install g++-4.9
Reading package lists... Done
Building dependency tree
g++-4.9 : Depends: gcc-4.9-base (= 4.9.2-0ubuntu1~14.04) but 4.9.2-10 is to be installed
Depends: gcc-4.9 (= 4.9.2-0ubuntu1~14.04) but it is not going to be installed
Depends: libstdc++-4.9-dev (= 4.9.2-0ubuntu1~14.04) but it is not going to be installed
idf@C55t-A:/etc/apt$
Edit 1
When I used aptitude, I get these warnings although it seems to work
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "en",
LC_ALL = (unset),
LANG = "en_US.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
