We have been making custom made initrd.gz generated through debian-installer for 10.04 and 12.04 ubuntu.
We have been partitioning the disk and have made it automated completely and ask user to answer only few questions.
The problem I am facing is as below:
You have mounted partition on /dev/sda
Would you like the installer to unmount it
In 14.04.1 ISO /dev/sda1 is mounted on to /media and doesn't get unmounted even if I use preseed/early_command string umount /media I have tried all options of umount –l –f
Due to this a user has one more question to answer.
Neither does partman/unmount_active boolean true work
Earlier in 12.04, It would not ask to unmount the disk as /dev/sda1 was never mounted to media.
Is there a solution to either unmount the disk or set the Boolean as true through preseed?
