I am using Ubuntu 14.04.2 LTS, and after a power failure, I cannot login.
The computer has been working fine for a few months before this suddenly happened.
Symptoms are:
- After an login attempt, screen blacks out for about 15 seconds, and returns to the login screen.
- I can log in as a guest without a problem
- I can log in as myself through tty1~tty6
I tried/checked the following with no success:
Changing
.Xauthorityownership didn't work
chown username:username .XauthorityChanging the user directory rights didn't work
sudo chmod -R u+w /home/[username]I tried meddling with lightdm
dpkg-reconfigure lightdmsudo mv ~/.Xauthority ~/.Xauthority.backup
sudo service lightdm restartThere was nothing in
.xsession-errorsTried
gdminstead oflightdm, but it had the exact same issueUninstalled
lightdmand reinstalled/tmpdirectory does showdrwxrwxrwt
None of these solutions I found on-line worked. Can anyone please help?
Edit 1):
When I typed sudo tail /var/log/lightdm/lightdm.log, there are 10 lines showing. (All starting with DEBUG:):
Activating VT 7
Activating login1 session c3
Session pid=8697: Greeter connected version=1.10.4
Session pid=8697: Greeter start authentication for [username]
Session pid=8769: Started with service 'lightdm', username [username]
Session pid=8769: Got 1 message from PAM
Session pid=8697: Propmpt greeter with 1 message
User /org/freedesktop/Accounts/User 1000 changed (repeated 3 times)
Also, when I type ls /usr/share/xsessions/, it shows
gnome.desktop ubuntu.desktop
Edit 2):
sudo grep 'lightdm:' /var/log/auth.log | tail gives the following, all starting with lightdm::
pam_ck_connector(lightdm:session): nox11 mode, ignoring PAM_TTY :0
pam_unix(lighdm:session): session closed for user [username]
PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
PAM adding faulty module: pam_kwallet.so
pam_unix(lightdm-greeter:session): session opened for user lightdm by (uid=0)
pam_ck_connector(lightdm-greeter:session): nox11 mode, ignoring PAM_TTY :0
pam_succeed_if(lightdm:auth): requirement "user ingroup nopasswdlogin" not met by user [username]"
(this one starts with sudo: instead of lightdm:) [username] : TTY=tty1 ; PWD=/home/[username] ; USER=root ; COMMAND=/bin/grep lightdm: /var/log/auth.log
