I am running a Lenovo T440p with a clean install of Ubuntu. No dual booting. Over the weekend I upgraded from Ubuntu 14.04 to 14.10. There were some package install errors that led to Ubuntu being booted in 'low-graphics' mode. I ultimately fixed the package issues by deleting my installed cisco VPN client. I was then able to do an apt-get update and apt-get upgrade.
Here is where all that backstory leads: after rebooting my system, its like the bios doesnt even know there is an OS installed at all. It can see the HD, but it wont boot to it. And I am unable to open GRUB in any way.
I used the Live CD to install and run boot-repair with no luck. It says it completed successfully, but does not seem to have made a difference.
Ive tried just mounting the drive so I can get the files I need and reformat the thing. But I cant seem to get that to run either. It seems to map correctly, but when trying to mount using:
sudo mount /dev/mapper/encrypted /media/encrypted
I get the following error:
mount: wrong fs type, bad option, bad superblock on /dev/mapper/encrypted, missing codepage or helper program, or other error
Running dmesg | tail from there doesnt seem to provide any actionable help.
I am getting desperate here. And any help either mounting the drive, or better-yet repairing the boot process would be eternally appreciated.
Basically there are two stages to this.
  1. decrypting
  2. mounting the Logical volumes
Assuming your drive is on sda5 (which is the Ubuntu default AFAIK but might be different)
sudo cryptsetup luksOpen /dev/sda5 luks
You are then promted for your password.
Than do the LVM stuff
sudo pvscan && sudo vgscan && sudo vgchange -a y
Use lsblk if you want to find out more information about the current layout of the connected drives after the vg are activated you can mount:
sudo mount /dev/ubuntu-vg/root /mnt
Now you should be able to acces the drive content. Repairing is basically a seperate question I think this might be a relevant answer How to restore a system after accidentally removing all kernels?
bacon
  • 158
