I'm on Kubuntu 11.04, and deleting in Krusader I get "Thrash has reached maximum size" even when I have 10M in ~/.local/share/Trash/files. So my question is why is that? How do I set the allowed size of the trash bin?
Adobe
  • 3,971
Easier still...
  • Open Dolphin
  • Select 'Control' from the top of the window
  • Select 'Configure Dolphin'
  • Select Wastbin
  • Un-check limit to maximum size
  • Select apply
And you don't even have to open a horrid terminal
user.dz
  • 49,176
Try Krusader Tools > Empty trash instead of empty trash button.
Removing trash metadata file works too - until you reach trash limit again - rm ~/.local/share/Trash/metadata
Kai
  • 203
This UserAction solves it:
mv %aList("Selected")% $HOME/.local/share/Trash/files
Edit:
The following works faster (but be careful)
rm -rf %aList("Selected")%
Adobe
  • 3,971
I had this problem and solved it in the File manager (Dolphin in my case) configuration i went to Trash tab and there switched "Full trash" option from "Show a warning" to "Delete biggest files from trash". I am guessing other file managers have similar option.
16851556
  • 677
