28
I installed Conda using its 32 bits .sh file from here.
Here are the essential parts of the installation procedure that worked fine:
Do you approve the license terms? [yes|no]
[no] >>> yes
Miniconda3 will now be installed into this location:
/home/begueradj/miniconda3
  - Press ENTER to confirm the location
  - Press CTRL-C to abort the installation
  - Or specify a different location below
[/home/begueradj/miniconda3] >>>
PREFIX=/home/begueradj/miniconda3
installing: python-3.4.2-0 ...
installing: conda-env-2.0.1-py34_0 ...
installing: openssl-1.0.1k-0 ...
installing: pycosat-0.6.1-py34_0 ...
installing: pyyaml-3.11-py34_0 ...
installing: readline-6.2-2 ...
installing: requests-2.5.1-py34_0 ...
installing: sqlite-3.8.4.1-0 ...
installing: system-5.8-1 ...
installing: tk-8.5.15-0 ...
installing: xz-5.0.5-0 ...
installing: yaml-0.1.4-0 ...
installing: zlib-1.2.8-0 ...
installing: conda-3.8.3-py34_0 ...
Python 3.4.2 :: Continuum Analytics, Inc.
creating default environment...
installation finished.
Do you wish the installer to prepend the Miniconda3 install location
to PATH in your /home/begueradj/.bashrc ? [yes|no]
[no] >>> yes
Prepending PATH=/home/begueradj/miniconda3/bin to PATH in /home/begueradj/.bashrc
A backup will be made to: /home/begueradj/.bashrc-miniconda3.bak
For this change to become active, you have to open a new terminal.
Thank you for installing Miniconda3!
begueradj@begueradj-HP-Compaq-6510b-KE130ET-ABF:~/Desktop$
When I type sudo conda install something, I get this error:
sudo: conda: command not found
How can I resolve this problem ?
muru
  • 207,228
Well, I'm not used to find answers to my question this quickly, but for this one I did:
I had only to remove the sudo before the conda command.
Explanation:
All conda commands must be run without super user privileges.
Hope it can help someone in the future.
16
If you are getting a CondaIOError with conda command, it means that the conda directory does not have enough permissions to download and save new libraries.
Just execute these commands in terminal, and you'll be good to go:
sudo chown -R username /home/username/path-to-conda-folder/
sudo chmod -R +x /home/username/path-to-conda-folder/
Change username and path-to-conda-folder according to your PC.
Hope this helps! :)
Saurabh
  • 261
11
You can do the following Before running the sudo command type
which conda
then use the full conda path
sudo ~/install/ananconda//5.1../etc install myPackageName
Anant Gupta
  • 219
If you decide to run with sudo permissions you shoud run conda specifying explicity the path of the conda executable. That path can ve investigated with which conda.
