Full error log:
starts here:
E:Unable to parse package file /var/lib/apt/lists/ubuntu.c3sl.ufpr.br_ubuntu_dists_trusty_universe_i18n_Translation-pt%%5fBR (1),
The item above is from universe and the binary below relates to it.
E:Problem opening /var/lib/apt/lists/ubuntu.c3sl.ufpr.br_ubuntu_dists_trusty-updates_main_binary-amd64_Packages, E:The package lists or status file could not be parsed or opened.
--and ends here.
It's not a merged list
It is happening in a brand new 14.04 Unity installation. Before I was running Ubuntu GNOME 14.04.
If I disable the universe repo I can update && upgrade without problems. It shows the relations between the items in the error. That is, without universe src does not have to parse the binary version of universe_i18n.
I'm running Package Manager Troubleshooting Procedures¹ to work around it meanwhile. ¹ https://help.ubuntu.com/community/PackageManagerTroubleshootingProcedure
I wanna solve it. Any ideas?
muru
  • 207,228
ftcosta
  • 121
What I suggest is clear the lists and obtain a fresh copy.
Clear the List(s):
Command:
sudo rm -rf /var/lib/apt/lists/*
Obtain a Fresh Copy of Lists:
Command:
sudo apt-get update
See if that rectifies the problem. :)
Solved
system settings > programs & upgrades # my system is in Portuguese
Go through all tabs and uncheck all sources (repos). Everything. It will comment the source.list and source.list.d/files* from top to bottom.
# The goal is to make a new source list
Close it with everything unchecked to make the system load an empty source
Close all apps and open a terminal Ctrl+Alt+T
sudo rm -rf /var/lib/apt/lists/* && sudo apt-get clean && sudo apt-get autoclean
Open settings > programs again and let Ubuntu find the best source. There is a button to do this.
Check the desired items in each tab
Close once again and reopen a terminal Ctrl+Alt+T
sudo apt-get update && sudo apt-get upgrade
Up and running
ftcosta
  • 121
