A while back I was trying to update from 12.10 and my roommate unpluged my laptop and ever since then I have not been able to open software updater or start up disk creator. It does not give an error message but it won't open. What can I do to solve this problem?
sudo apt-get update
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
sudo apt-get upgrade
Jos
  • 30,529
  • 89
  • 96
When you interrupt the package manager a couple of things can happen..
  • it could have been stopped while either installing/configuring a package
  • left the lock on the upgrade process so you can't run two upgrades at once.
In a general sense, exit any package managers (synaptic, software center) and issur the following from a terminal prompt.
sudo rm /var/lib/apt/lists/lock
sudo rm /var/cache/apt/archives/lock
sudo apt-get update
Scott Goodgame
  • 2,646
  • 16
  • 20
