All was working well in my Ubuntu 14.04. Suddenly I couldnt search any apps through search (by pressing super key).
I used to type "Terminal" or "System Monitor" and it would display those apps. But now, when I typed "Terminal" and any other apps like Chromium, it displays "sorry no match found". How to resolve this?
I can open System Monitor by pressing Alt + F2 and using the command gnome-system-monitor.
Jos
  • 30,529
  • 89
  • 96
Anbu
  • 529
Accidentally changed settings?
It could be that you accidentally changed the default search settings in Dash. I would check two things first:
  1. run:
    gsettings get com.canonical.Unity.Lenses home-lens-default-view
    This should return a list, in which applications should appear, like:
    ['applications.scope', 'files.scope']
    If not, you can set it to default by the command:
    gsettings set com.canonical.Unity.Lenses home-lens-default-view "['applications.scope', 'files.scope']"
  2. The applications Lens might be disabled for some reason, to check:
    gsettings get com.canonical.Unity.Lenses disabled-scopes
    It should return:
    @as []
    If not, reset it by:
    gsettings set com.canonical.Unity.Lenses disabled-scopes "[]"
If that doesn't work
If all fails, as an alternative, you can reset the Unity configuration as described here:
  1. You'll need Unity Tweak Tool:
    sudo apt-get install unity-tweak-tool
  2. Run the command:
    unity-tweak-tool --reset-unity
Jacob Vlijm
  • 85,475
