-1
I'm trying to use Intel Graphics Installer, but i get the following error:
E:GPG error: http://ppa.launchpad.net trusty InRelease: Clearsigned file isn't valid, got 'NODATA' (does the network require authentication?)
I've searched through the internet, but none of the answers i found helped me to solve this issue.
Also, using the command
sudo apt-get update
I get a similar error at the end, sometimes accusing different ppa's. What should i do?
muru
  • 207,228
I've experienced this at one point or another.
This is generally a network issue.
Are you:
  • Behind/Forced to use a proxy?
  • Have a spotty internet connection?
  • Etc...
You should check your network. If that doesn't solve your issue(s), you may need to contact your ISP.
