How to collect command's output/results to the log file? What command can write all msg's in shell to the file?
Asked
Active
Viewed 500 times
To put some output to file you can use
ls /path_to_folder/ > list.txt
This will put output from ls command to file with name list.txt witch will be created on curent location.
2707974
- 10,758
You can use stream redirection to put output into a file.
yourcommand > filename
Will create a new file containing the output of yourcommand.
anewcommand >> filename
Will append the output of anewcommand onto the end of the same file previously used.
Arronical
- 20,241
