How to install GUI on Ubuntu Server 12.04 from USB stick without internet connection
I take it you have ubuntu desktop on the usb. Or else you have to visit http://cdimage.ubuntu.com/ubuntu/releases/12.04/release/ and download the ubuntu-desktop image for the your architecture. And then create a boot usb.
Firstly you have to remove (or comment them by adding a # in front) all lines from /etc/apt/sources.list and /etc/apt/sources.list.d/* so you can call
sudo apt-get update
sudo apt-get dist-upgrade
Without getting any errors.
Once you have the usb connected you can add the deb src lines to /etc/apt/sources.list by using the apt-cdrom tool.
Description on how to use apt-cdrom can be seen here: https://help.ubuntu.com/community/AptCdrom
Basically it boils down to these commands.
sudo apt-cdrom ident
sudo apt-cdrom -d "your-usb-mount-point" -r
Once you have the correct apt lines you can must install the ubuntu-desktop package in order to get the gui.
sudo apt-get update
sudo apt-get install ubuntu-desktop
Good luck!
- 589
