I am running Ubuntu Gnome 14.04 LTS, Gnome Classic and I want to turn off the auto-maximizing of windows that occurs when I drag a window to the top of the screen. I admit to being confused about the functionality and meaning of compiz, metacity, gconf-editor, etc., but I have tried to follow the instructions that worked for other people with this same problem, and none of them has worked.
I tried using Compiz Configuration Settings Manager (CCSM) to change the Top Edge behaviour from "maximize" to "None" as described in Turning off auto-maximizing of windows in 14.04. I also used gconf-editor to set top_edge_action to 0, as described in How to turn off Compiz's "drag to maximize" behaviour? . I also used CCSM to uncheck "Maximize Vertically if Screen edge hit" as described in How to disable the auto resizing of Windows when you touch the top or bottom. I set the Grid Snapback Threshold to 0 for the top edge in CCSM and top_edge_threshold to 0 in gconf-editor (this was my idea; I don't know if it makes sense or not). Finally I used CCSM to disable the "Grid" feature entirely. At each step there was no change in behaviour and now I find myself stuck with this annoying feature. What else can I try?
kpb
I use 16.04 Gnome Classic, metacity.
Managed to disable the irritating 'auto resize' problem:
  1. Open 'dconf Editor' ;
  2. Search for edge-tiling
  3. Uncheck the corresponding box.
Use the keyboard shortcuts for window positioning instead of the mouse.
CTRL-ALT-(Numpad)8 for window to top, CTRL-ALT-(Numpad)2 for window to bottom, etc.
For more search for the question regarding keyboard shortcuts in Ubuntu.
Zanna
  • 72,312
Elder Geek
  • 36,752
I think the hotcorners tool in Unity Tweak Tool may work for you:
Hotcorners
Disclaimer: I have never used this app, so I am not entirely sure what its features are.
Zanna
  • 72,312
RootFAIL
  • 169
I am running a similar config, with Gnome Classic, and hit the same problem.
Guesswork led to this gconf-editor solution. Change
/apps/compiz-1/plugins/snap/screen0/options/avoid_snap [0]
to
/apps/compiz-1/plugins/snap/screen0/options/avoid_snap [1]
Zanna
  • 72,312
Don
