This Python script from my Unix.StackExchange answer appends stdin to a tar file, giving it an arbitrary name, using Python's tarfile library. It seeks back in the tar to rewrite the header with the right size at eof. The usage would be:
cat foo | tarappend -t mytar -f foo
tar tvf mytar
Here's the tarappend python script:
#!/usr/bin/python
# concat stdin to end of tar file, with given name. meuh on stackexchange
# $Id: tarappend,v 1.3 2015/07/08 11:31:18 meuh $
import sys, os, tarfile, time, copy
from optparse import OptionParser
try:
import grp, pwd
except ImportError:
grp = pwd = None
usage = """%prog: ... | %prog -t tarfile -f filename
Appends stdin to tarfile under the given arbitrary filename.
tarfile is created if it does not exist.\
def doargs():
parser = OptionParser(usage=usage)
parser.add_option("-f", "--filename", help="filename to use")
parser.add_option("-t", "--tarfile", help="existing tar archive")
(options, args) = parser.parse_args()
if options.filename is None or options.tarfile is None:
parser.error("need filename and tarfile")
if len(args):
parser.error("unknown args: "+" ".join(args))
return options
def copygetlen(fsrc, fdst):
"""copy data from file-like object fsrc to file-like object fdst. return len"""
totlen = 0
while 1:
buf = fsrc.read(16*1024)
if not buf:
return totlen
fdst.write(buf)
totlen += len(buf)
class TarFileStdin(tarfile.TarFile):
def addstdin(self, tarinfo, fileobj):
"""Add stdin to archive. based on addfile() """
self._check("aw")
tarinfo = copy.copy(tarinfo)
buf = tarinfo.tobuf(self.format, self.encoding, self.errors)
bufoffset = self.offset
self.fileobj.write(buf)
self.offset += len(buf)
tarinfo.size = copygetlen(fileobj, self.fileobj)
blocks, remainder = divmod(tarinfo.size, tarfile.BLOCKSIZE)
if remainder > 0:
self.fileobj.write(tarfile.NUL * (tarfile.BLOCKSIZE - remainder))
blocks += 1
self.offset += blocks * tarfile.BLOCKSIZE
# rewrite header with correct size
self.fileobj.seek(bufoffset)
self.fileobj.seek(self.offset)
self.members.append(tarinfo)
class TarInfoStdin(tarfile.TarInfo):
def __init__(self, name):
if len(name)>100:
raise ValueError(name+": filename too long")
if name.endswith("/"):
raise ValueError(name+": is a directory name")
tarfile.TarInfo.__init__(self, name)
self.size = 99
self.uid = os.getuid()
self.gid = os.getgid()
self.mtime = time.time()
if pwd:
self.uname = pwd.getpwuid(self.uid)[0]
self.gname = grp.getgrgid(self.gid)[0]
def run(tarfilename, newfilename):
tar = TarFileStdin.open(tarfilename, 'a')
tarinfo = TarInfoStdin(newfilename)
tar.addstdin(tarinfo, sys.stdin)
tar.close()
if __name__ == '__main__':
options = doargs()
run(options.tarfile, options.filename)
