12
I've seen an article describing how to use VLC as a live wallpaper for the desktop, however the options mentioned there only refer to Windows.
What would I need to do to achieve the same result?
Seth
  • 59,332
Uri Herrera
  • 15,318
VLC does support video as background. Simply run the cvlc command:
cvlc --video-wallpaper --no-audio /your/videofile
There are other helpful options to cvlc such as aspect ratio etc. You can find them using
vlc --help
If you still want icons on your desktop you may need to take a look at xwinwrap, but it requires a little digging. There is an option to set movies as background. I dont know how to do it with VLC but it has been done with mplayer.
vlc does not work on either windows or Linux for the backdrop. The only thing it does is play full screen with no controls. It does NOT place the video in the background. I have been working with it for over two years and that is the best I can get out of it!
