I did something real dumb. I was creating tarballs of files in my /var/ folder. The tarball i created was put into /tmp/test.tar
In the process of testing the extraction process, I meant to delete /tmp/var/ but ended up doing a
rm -r on /var
via the command line.
I know... ugh.
The good news is that I only had apache2 / php5 running on this test box. But I'm wondering if there's an easy way to recover my files? From what I've read so far in other posts, the answer is no. I'm trying to reinstall apache and php5 but of course, I'm getting errors. I have another Ubuntu box with a similar set up... so I copied over /var/lib/dpkg folder which got me a little further...
But now when i do an apt-get install apache2, I get the following error:
Reading package lists... Done
Building dependency tree
Package apache2 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'apache2' has no installation candidate
I'm relatively new to Linux and am not so saavy , as you can tell! Just wondering if you had any tips on a quick recovery?
Thanks.
EDIT 1
I ran
sudo apt-get update
and it seemed to run properly.
Then I tried
$ sudo apt-get install apache2
Some packages could not be installed.
This may mean that you have requested an impossible situation or if you are
using the unstable distribution that some required packages have not
yet been created or been moved out of Incoming. The following
information may help to resolve the situation:
apache2 :
Depends: apache2-bin (= 2.4.7-1ubuntu4.1) but 2.4.10-1ubuntu1 is to be installed
Depends: apache2-data (= 2.4.7-1ubuntu4.1) but 2.4.10-1ubuntu1 is to be installed
So I tried to do the following:
test@testpc:/$ sudo apt-get install apache2-bin
apache2-bin is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 32 not upgraded.
test@testpc:/$ sudo apt-get install apache2-data
apache2-data is already the newest version.
As you can see, it's not upgrading... Any other suggestions would be appreciated.
EDIT 2
I checked the box where I copied /var/lib/dpkg from and it's running ubuntu 14.10 whereas this one is running 14.04. Does that matter?
dot
  • 535
You've got 2 possibilities:
  1. Restore your System Back-up (you're definitely user type 4)
  2. Reinstall and start making System Back-ups
There! Yhat's it. Those are the 2 quick fixes for your system.
Anything else will lead to a lot of headaches, problems cropping up in a few days, weeks, months or even years!
Fabby
  • 35,017
It happened to me once, and something stupid actually solved it. I tried to update and it complained about missing /var/dpkg/ or whatever, I just created that missing directory or file and kept repeating apt-get update. Later I encountered this error message: dpkg: error processing some-package (--configure): and this answer helped me, whenever that error occurred, I just replaced install ok whatever with install ok installed. Now, this, of course, could be dangerous and might mess things up, but if reinstalling the OS is the only choice you are left with, then why not try this as a penultimate resort? And by the way, keep also trying to clean, autoclean and autoremove. So the steps are something like this:
sudo apt-get updte
the error message says: blah/blah/blah file/directory doesn't exist, just go ahead and create those directories/files (empty of course) and repeat the update process. When you encounter, for example,
dpkg: error processing some-package (--configure): dependency problems - leaving unconfigured
edit this file: /var/lib/dpkg/status
and find :
Package: some-package Status: install ok whatever
replace whatever with installed and repeat sudo apt-get update. Keep doing this until you are happy.
quanta
  • 249
