Occasionally my pc wont resume from suspend (to ram) properly.
Instead of the expected "resume" the pc just does a normal boot.
My biggest problem is that I have no clue where to look for that error. I am missing a point to start, especially because it happens not very often and I can't reproduce it.
I'm running on 64 bit natty.
My PC:
  • AMD Phenom II X4 955BE
  • Gigabyte GA-770TA-UD3
  • ATI Radeon HD 5770
imbaer
  • 2,911
this solved my problem, but my computer did the reboot all the time instead of resuming, not sometimes y hope this helps
this worked for mi before i install ati drivers Edit the file /etc/default/grub (as root)
Change the line with:
GRUB_CMDLINE_LINUX=""
to:
GRUB_CMDLINE_LINUX="acpi_sleep=nonvs"
run command as root
update-grub
and this other one worked just fine after installing the ati drivers
"I've solved a similar issue (reboot on resume) with a Sony Vaio VGN-FW51ZF by changing the last line of the file /etc/acpi/sleep.sh from pm-suspend to pm-suspend --quirk-radeon-off (guess it was a problem related with ATI proprietary drivers)."
so thanks for those tips and i hope this save you some time
from Suspend fails (reboot on resume) and no hibernate option
manuel
  • 26
