When doing this on Ubuntu server 14.04:
camilstaps@localhost:~$ sudo useradd --home-dir /var/www/xxx.camilstaps.nl/ --no-create-home --root /var/www/xxx.camilstaps.nl/ --shell /bin/sh xxx
I'm getting the error:
useradd: cannot lock /etc/passwd; try again later.
I checked and tried the following (found the suggestions all over the internet):
  • Obviously, I'm using sudo
  • There exists a file /etc/.pwd.lock, but it is empty and removing it doesn't help
  • There are no other *.lock files in the /etc directory
  • The filesystem is not full (14G available on /)
  • Rebooting the server doesn't remove the lock.
I'm stumped. How can I unlock /etc/passwd?
df -ih output
camilstaps@localhost:~$ df -ih
Filesystem     Inodes IUsed IFree IUse% Mounted on
/dev/vda1        1,3M  228K  1,1M   18% /
none             125K     4  125K    1% /sys/fs/cgroup
udev             124K   404  123K    1% /dev
tmpfs            125K   386  124K    1% /run
none             125K     5  125K    1% /run/lock
none             125K     1  125K    1% /run/shm
none             125K     2  125K    1% /run/user
You can use adduser instead of useradd. adduser also provides an interactive session to configure your Linux user and also creates the necessary /home/username/ directory automatically.
sudo adduser <username>
By the way, there is no difference between adduser and useradd. They both serve the same purpose.
Found this and this solves the problem
You need to remove all the four files and then try
/etc/passwd.lock
/etc/shadow.lock
/etc/group.lock
/etc/gshadow.lock
Logging as the root user
$ sudo su
rm –rf /etc/passwd.lock
rm –rf /etc/shadow.lock
rm –rf /etc/group.lock
rm –rf /etc/gshadow.lock
Then try your command.
Trect
  • 344
