I'm a developer and am often working on multiple different projects. It would help me a lot to have a software where I can create a profile for each project. If I start a profile it should open other programs I configured before and display them inside a single window. It should be possible to arrange them in tabs or also on a screen, one on the left and one on the right or similar.
I think mainly about browsers, PDF-viewers and terminals. This will give me access to the bug-tracker in a browser, log output in a console, specifications in a PDF and so on. It would make switching between projects much easier.
Is there anything or does anyone have a hint how it could be implemented with a scripting language?
Oli
  • 299,380
Christian
  • 274
What I'm offering is little more than a theory. It may lead nowhere.
There are alternative window-managers like bluetile, xmonad and awesome that can nest multiple windows in a nice tiling configuration (that is, all child windows are placed next to each other, rather than being allowed to overlap.
They can all (and there are a lot more than just those) be scripted in various languages. bluetile and xmonad both use Haskell while awesome uses lua.
The problem is, they replace the standard window manager. bluetile is the only one designed to work alongside traditional Gnome components so you might have most initial luck with that. Either way, you might battle to keep both a traditional desktop and be able to swap out for a tiled one. You might find that creating a new user for each project where each has its own desktop configuration, is what works best.
That said, you might find you prefer a tiled desktop for everything.
enzotib
  • 96,093
Oli
  • 299,380
KDE provides exactly this functionality with a feature called 'activites'. This blog post gives a good overview of the concept:
http://hanschen.org/2011/02/04/activities-a-change-in-workflow/
scottl
  • 2,588
