I have been trying to install Google Earth on my netbook running 11.04. I have the .deb file in my directory /home/andy/ but when I use terminal with the command sudo dpkg -i /home/andy/googleearth_6.0.3.2197+0.6.0-1_i386.deb, I get the following error:
dpkg: error processing /home/andy/googleearth_6.0.3.2197+0.6.0-1_i386.deb
(--install): cannot access archive: No such file or directory
Is this a typo on my part or is the sudo command accurate and it could be another issue? Also when I double-click this file, it automatically open the software centre application which is then frozen and I have to close it. Can a .deb be installed any other way?
Rinzwind
  • 309,379
The error you receive is about the package not being found, or not being readable. It should not be about a corrupted package.
As it has been already asked to you, please report output of:
ls -l /home/andy/googleearth_6.0.3.2197+0.6.0-1_i386.deb
You can also try the following command:
dpkg --info /home/andy/googleearth_6.0.3.2197+0.6.0-1_i386.deb
This should return some basic information about the package, and so it would do a couple of checks useful in your situation:
  • the file exists and it's readable
  • the file is a real .deb package and it is not corrupted
bitwelder
  • 386
I just downloaded Google earth 32bit from here:
http://www.google.com/earth/download/ge/agree.html
When Chromium finished downloading, I just clicked on it once and it installed no problem. I'm running it on a Dell Optiplex 755 micro tower with integrated Intel Q35 graphics so it's not the most powerful PC in the world but Google earth runs just fine.
