I'm that kind of user who likes to have different browsers, media players, etc. Today I just wanted to try out Opera and Google Chrome, but I don't want to use them anymore so I thought that I remove them. The problem is I can't find them in Ubuntu Software Center or when I use 'remove opera' in terminal it doesn't work. Can you tell me how to remove them properly?
Braiam
  • 69,112
6 Answers6
Open a Terminal and put in:
sudo apt-get remove opera-stable
to remove opera and
 sudo apt-get remove google-chrome-stable
to remove chrome
poldi
  • 136
In Software Center go to Installed and from right side of the Installed click on the down arrow button and select Unknown - You will see Opera and Chrome there.
Muzaffar
  • 5,677
Are you sure that you have installed these two pieces of software successfully?
Try this:
dpkg -s opera-stable google-chrome-stable
If you see dpkg-query: package 'nlll' is not installed and no information is available that means you didn't install that.
Also, if you install that, you will see lots of files.
muru
  • 207,228
Mr.m
  • 96
Use purge to delete the configurations as well
example:
sudo apt-get purge opera-stable
Dave
  • 962
After a long searching process, I used sudo snap remove opera-beta command and it is working. I forget that i installed opera-beta from snap.
Lorenz Keel
  • 9,511
I solved with this command : sudo snap remove opera
salvo720
  • 111
