After I completed the installation of Ubuntu alongside Windows I don't get the option for dual boot, it boots straight to Windows. I used an USB stick to install.
Byte Commander
  • 110,243
Use gparted to make sure you haven't deleted your Windows partition and installation
If you haven't overwritten it, I suggest reading this. It should help you on your way to restoring your option to dual-boot
FYI: I obtained this link rather easily by doing a simple search. I can only imagine this question has been answer 1000000 times
BiggJJ
  • 1,249
Please boot into a live session of Ubuntu and run boot-repair. First, after loading into a live session; connect to the Internet.
Open a new Terminal ctrl+alt+t then type the following commands (press Enter after each line):
sudo add-apt-repository ppa:yannubuntu/boot-repair
sudo apt-get update
sudo apt-get install -y boot-repair && boot-repair
after that you will get a pop up that looks like this, Choose Recommended repair and do what it says, This should repair GRUB to the MBR allowing you to see Windows and Ubuntu.
Mudit Kapil
  • 2,081
Krea
  • 16
