I created a script to back up my databases and my websites. It runs fine if I run it straight up but it's not running at all as a cron job.
I created a symbolic link to the script:
lrwxrwxrwx 1 root root    44 Feb 11 14:58 backupsql -> /home/techguyalabama/dropboxbackup/backupsql
If I run the backupsites from the /etc/cron.daily directory, it does prompt me for my password. I'm not sure if that is the issue. If it is, how do I avoid that?
I did make a change to the time that cron jobs run. Maybe that's a no-no also?
This is in my crontab:
# m h dom mon dow user  command
17 *    * * *   root    cd / && run-parts --report /etc/cron.hourly
05 5    * * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
30 5    * * 6   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.weekly )
00 6    1 * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.monthly )
I did restart the server to see if that made a difference and it did not.
I also checked the syslog, from this post Where is the cron / crontab log?, to see if there was anything in there about the backupsql:
tail -f /var/log/syslog | grep backupsql
I got no results.
Anyone see what I am doing wrong?
EDIT#1
This is my backupsql script:
#!/bin/bash
DB_BACKUP="/home/techguyalabama/dropboxbackup/sqlbackup"
DB_USER="root"
DB_PASSWD="wouldntyouliketoknow"
HN=`hostname | awk -F. '{print $1}'`
# Create the backup directory
mkdir -p $DB_BACKUP
# Backup each database on the system
for db in $(mysql --user=$DB_USER --password=$DB_PASSWD -e 'show databases' -s --skip-column-names|grep -viE '(staging|performance_schema|information_schema)');
do mysqldump --user=$DB_USER --password=$DB_PASSWD --events --opt --single-transaction $db | gzip > "$DB_BACKUP/mysqldump-$HN-$db-$(date +%Y-%m-%d).gz";
done
/home/techguyalabama/dropboxbackup/dropbox_uploader.sh upload /home/techguyalabama/dropboxbackup/sqlbackup/*.* /sqlbackup/
rm -f /home/techguyalabama/dropboxbackup/sqlbackup/*.*
Zanna
  • 72,312
ErocM
  • 531
Don't forget that these cron scripts are run as root, which means that for example the home directory refers to root's home directory, and so on.
Since your script asks for a password, you probably need to run it with root privileges so you can't just create the usual .anacron/cron.daily and put your script in there, you have to use /etc/cron.daily so it executes with the right permissions.
I think the easiest solution is to go through your script and check whether it uses user-specific variables like $HOME, in which case you have to replace these with the ones for user 'techguyalabama'.
I just followed this answer from How to Setup a root cron Job Properly:
If you want to run a script as a normal user:
crontab -e
And add the line:
07,37 * * * * /usr/bin/tunlrupdate.sh
If you want to run your script as root:
sudo crontab -e
And add the same line:
As the user and it worked right away.
ErocM
  • 531
