Firefox selenium driver seems to be crashing (perhaps because I'm on Firefox-beta ppa?):
>>> from selenium import webdriver
>>> webdriver.Firefox
<class 'selenium.webdriver.firefox.webdriver.WebDriver'>
>>> webdriver.Firefox()
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "/usr/local/lib/python2.7/dist-packages/selenium/webdriver/firefox/webdriver.py", line 59, in __init__
    self.binary, timeout),
  File "/usr/local/lib/python2.7/dist-packages/selenium/webdriver/firefox/extension_connection.py", line 47, in __init__
    self.binary.launch_browser(self.profile)
  File "/usr/local/lib/python2.7/dist-packages/selenium/webdriver/firefox/firefox_binary.py", line 66, in launch_browser
    self._wait_until_connectable()
  File "/usr/local/lib/python2.7/dist-packages/selenium/webdriver/firefox/firefox_binary.py", line 100, in _wait_until_connectable
    raise WebDriverException("The browser appears to have exited "
selenium.common.exceptions.WebDriverException: Message: The browser appears to have exited before we could connect. If you specified a log_file in the FirefoxBinary constructor, check it for details.
So I tried installing the chromium driver but it still fails with selenium:
>>> webdriver.Chrome()
  File "/usr/local/lib/python2.7/dist-packages/selenium/webdriver/chrome/webdriver.py", line 59, in __init__
    self.service.start()
  File "/usr/local/lib/python2.7/dist-packages/selenium/webdriver/chrome/service.py", line 66, in start
    "ChromeDriver executable needs to be available in the path. "
selenium.common.exceptions.WebDriverException: Message: ChromeDriver executable needs to be available in the path. Please download from http://chromedriver.storage.googleapis.com/index.html and read up at http://code.google.com/p/selenium/wiki/ChromeDriver
Am I missing something or is this package completely broken? I have both Chromium and Google Chrome installed for testing, if that matters.
karel
  • 122,292
  • 133
  • 301
  • 332
NoBugs
  • 1,440
  • The Firefox webdriver failed with this message:
    "The browser appears to have exited before we could connect"
    Which means that selenium managed to find it. I also believe that beta versions can be the root cause as it works out of the box for me using the repo version.
  • For Chromium, you have to install the following packages:
    sudo apt-get install python-selenium chromium-chromedriver
    And fix the libui_base.so library path (See Chromedriver on Ubuntu 14.04 - error while loading shared libraries: libui_base.so)
  • To use the Chrome webdriver install the following dependency:
    And download the Chromedriver from here, select the one corresponding to your architecture e.g:
    http://chromedriver.storage.googleapis.com/2.14/chromedriver_linux64.zip or http://chromedriver.storage.googleapis.com/2.14/chromedriver_linux32.zip
    Extract the chromedriver file for example in your $HOME folder.
    Then to start the chromedriver from python, open a terminal and type:
    $ python
    Python 2.7.6 (default, Mar 22 2014, 22:59:56)
    [GCC 4.8.2] on linux2
    Type "help", "copyright", "credits" or "license" for more information.
    >>> import os
    >>> driver = webdriver.Chrome(os.path.expanduser('~/chromedriver'))
Finally I'd recommend to use the package version of python-selenium available from the Ubuntu repositories to avoid installation in /usr/local/lib.
