hey i really need some help .this is what happened my laptop fell(it was running windows 7) and the computer stopped working normally.i decided to connect it to my desktop(which already contained a hard disk) to try and recover the info.i thought since there was two hard disks that i had to use raid instead of ahci. i then changed it back to ahci when i released it was wrong .i detached my desktop hd and booted into live image .but i keep receiving the following text that flashes before the os starts:
"the following are warnigs that were detected during this boot. these can be viewed in setup on the event log page WARNING:A problem with the hard drive has been detected."
after i boot i can see the hard disk but i cant access it, i get get this message when i try to :
"Unable to mount location
Error mounting: mount exited with exit code 13: ntfs-mst-post-read-fixup-warn:
Record 1 has no FILE magic oxffffffff)
Failed to open inode $MFTMirr: Input/output error
Failed to load $MFTMirr: Input/output error
Failed to mount idev'sda3: Input/output error
NTFs is either inconsistent, or there is a hardware fault or it's a
SoftRAID/FakeRAID hardware. In the first case run chkdsk on Windows
then reboot into Windows twice. The usage of the If parameter is very
important! If the device is a SoftRAID/FakeRAID then first activate
it and mount a different device under the Idewmapper/ directory (e.g.
Idev/mapper/nvidia-eahaabcc1). Please see the 'dmraid documentation
for more details."
plz be specific and detailed. thx
