26
How can I determine the name of the display manager in use solely by using the command line?
Zanna
  • 72,312
Short answer:
As mentioned in this answer on Unix & Linux, you should be able to get that from:
cat /etc/X11/default-display-manager
I tried it on both Unity and XFCE, both worked.
Jacob Vlijm
  • 85,475
Other way to find more detailed information about the window manager you're using is by running either neofetch or screenfetch. Both are similar and are available in Debian repositories. I install Neofetch and it show my WM also to be WM: Mutter.Result of screenfetch and neofetch
you can install them in debian systems CLI by :
sudo apt install neofetch screenfetch
tedy58
  • 56
