47
I use catdoc to preview Word documents from the command line. Is there something similar for HTML?
In other words I would like to do cathtml Webpage.html | less and get more or less a man page look output.
fossfreedom
  • 174,526
5 Answers5
40
One solution is to use lynx -dump, as in
lynx -dump file.html
or
echo "<div>this is a div</div>" | lynx -dump -stdin
Better:
Use w3m -dump, it respects the page layout. It is awesome.
sudo aptitude install w3m
w3m -dump file.html
echo "<div>x</div>" | w3m -dump -T text/html
You can set the number of columns of the terminal for getting the better layout, for example, if you are using a full-window terminal, 200 can be a good try:
w3m -dump -cols 200 file.html
fiatjaf
  • 502
24
You can use html2text to look into an HTML document from command line.
sudo apt-get install html2text
html2text Webpage.html | less
but not exactly a look similar to man pages, it depends on the html input, of course.
enzotib
  • 96,093
18
You could use w3m which should already installed - if however it isn't
sudo apt-get install w3m
An example command syntax:
w3m -dump askubuntu.com | less
It can be used with both URL's as well as file-based html files
w3m -dump index.html | less
fossfreedom
  • 174,526
There are these so-called text html browsers, of which I have successfully tested Lynx and ELinks. Of which ELinks has become my favorite.
Anyway, they are different than a "web page previewer" as you suggest in your question. They are more like active real-time browsers, which carry lots of useful features for easy web browsing and of course, you can also use it for local/remote web pages preview.
Information about Lynx is in the Wikipedia and can be reached clicking here. The information related to the ELinks is here.
My ELinks screenshot for you to see ELinks in action:
Damian
  • 105
You can combine a use of html2text and mdless.
html2text Webpage.html | mdless
Alternativly plus curl to download the file first
curl https://askubuntu.com | html2text | mdless
The curl does download the file in the stdin of html2text. This gives mdless the markdown which will be shown like a pager.
It is not the same as the man pages. And you can't click on links like on real browser, for that use w3m or elinks
fossdd
