11
I have been trying to find a way to remove the Ubuntu One entry from the indicators' panel.
I have removed the ubuntuone file from /usr/share/indicators/applications
and edited it out of the seendb.keyfile in ~/cache/indicators/messages/
but it keeps returning.
I just want it gone, as I do not need it at all.
How can I do it? I have Ubuntu Natty amd64.
Roo79x
  • 215
If instead of blacklisting the menu item you completely want to get rid of Ubuntu One, remove the following packages:
sudo apt-get purge ubuntuone-client python-ubuntuone-client python-ubuntuone-storageprotocol
After logging out and in again, Ubuntu One (and the menu item) should be gone.
htorque
  • 66,086
User a terminal and make the directory
mkdir -p ~/.config/indicators/messages/applications-blacklist/
Files in here should be paths to .desktop files which will be blacklsited on startup. The .desktop files in question are located in
/usr/share/indicators/messages/applications
so you can make symlinks from there to this directory. Thus
ln -s /usr/share/indicators/messages/applications/menuItem ~/.config/indicators/messages/applications-blacklist/menuItem
will remove menuItem from the messaging menu. Run
ls /usr/share/indicators/messages/applications
to see what the names of the .desktop files are and look for the one mentioning Ubuntu One.
You can run
killall gnome-panel
to see the changes immediately. Else, a logout should work as well.
Kris Harper
  • 13,705
Now that Ubuntu One is dying, I wanted to remove the Ubuntu One indicator. I realized that the above methods either hide the indicator or remove the application, not the indicator itself.
So to remove the Ubuntu One indicator from the top menu bar:
sudo apt-get remove indicator-ubuntuone
