I am trying to install an NFS server on my Ubuntu 12.04 machine but everytime it gives me an error like this:
david@machineA:~$ sudo apt-get install nfs-common nfs-kernel-server
Reading package lists... Done
Building dependency tree
nfs-common is already the newest version.
 nfs-kernel-server : Depends: nfs-common (= 1:1.2.5-3ubuntu3) but 1:1.2.5-3ubuntu3.1 is to be installed
Below is the output of lsb_release -a:
david@machineA:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 12.04 LTS
Release:        12.04
Codename:       precise
Is there anything wrong I am doing? How can I resolve this issue?
kos
  • 41,268
arsenal
  • 2,073
Try running the following commands in this order:
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get update
sudo apt-get install nfs-kernel-server
This will basically force the package cache to be updated, as well as upgrade other system utilities.
A problem you may be having is that you're specifying nfs-common, which gets the latest version. IIRC, apt will fulfill all dependencies (versions included) automagically, but forcing the install of nfs-common installs a too-new version of it.
Kaz Wolfe
  • 34,680
