60
I want to build the Empathy in Ubuntu 11.04. When I follow the build process,
 ./autogen.sh
The shell said to me that
libtoolize: copying file `m4/lt~obsolete.m4'
checking for autoconf >= 2.53...
testing autoconf2.50... not found.
testing autoconf... found 2.67
checking for automake >= 1.9...
testing automake-1.11... found 1.11.1
checking for libtool >= 1.5...
testing libtoolize... found 2.2.6b
checking for glib-gettext >= 2.2.0...
testing glib-gettextize... not found.
***Error***: You must have glib-gettext >= 2.2.0 installed
to build Empathy.  Download the appropriate package for
from your distribution or get the source tarball at
ftp://ftp.gtk.org/pub/gtk/v2.2/glib-2.2.0.tar.gz
But when I cannot find the way to install glib. What should I do to install that in ubuntu 11?
You need libglib2.0-dev for glib-gettext. You can install it with
sudo apt-get install libglib2.0-dev
binW
  • 13,194
14
you also need to install libgtk2.0-dev in order to install glib completely (glib is a part of : libgtk2.0-dev)
sudo apt-get install libgtk2.0-dev
see this link for more explaination: installing gtk and glib
Ali.A
  • 325
I recommend you search for available ppa's if you want to just checkout the newer empathy than you have. I think this ppa is the best bet Or just do this
sudo add-apt-repository ppa:telepathy/ppa
Or if you need to build it.
sudo apt-get build-dep empathy
which will install all the dependencies required to build empathy from source.
sagarchalise
  • 24,306
