If I make a btrfs snapshot of my / folder as described here, I can't roll back until I restart the PC, because I can't delete the old btrfs subvolume with btrfs subvolume delete @_baroot. It will simply tell me it's still in use.
Asked
Active
Viewed 1,915 times
I doubt that this is possible or even should be possible without a reboot. The root directory holds some pretty important system parts that shouldn't be changed at runtime. You can either
copy the files or directories you want to roll back with
cp --reflink,boot a live system and move the snapshot folder around, or
change the default subvolume (source)
# btrfs subvolume list / ID 258 gen 9512 top level 5 path root_subvolume ID 259 gen 9512 top level 258 path home ID 260 gen 9512 top level 258 path var ID 261 gen 9512 top level 258 path usr # btrfs subvolume set-default 258 /and reboot.
David Foerster
- 36,890
- 56
- 97
- 151
