I am an maintainer for a lot of computers in my town running ubuntu 12.04 and 14.04 with mate desktop, this is to help people just having a computer that just works :), and i cannot make them all do terminal work, hense having a .deb install they can download from dropbox via facebook annonce to them will be much better.
So... i want to create a .deb file that does:
apt-get install compiz compiz-plugins compiz-plugins-extra compizconfig-settings-manager -y
and makes the config file in ~/.config/compiz-1/compizconfig/Default.ini so everything works, i will however advice them to start of by ALT + F2 _ compiz --replace to see if everything works ok.
But how do it do this?, i tried apt-get install in control but of course this does not work as it can't start a different install process while instilling this .deb...
this is how i have tried so far...
#!/bin/sh
mkdir ~/.config/compiz-1
mkdir ~/.config/compiz-1/compizconfig
echo "[ezoom]
s0_zoom_in_button = <Super>Button4
s0_zoom_out_button = <Super>Button5
[core]
s0_active_plugins = core;composite;opengl;compiztoolbox;decor;wall;resize;regex;imgpng;snap;commands;mousepoll;place;grid;move;animation;scale;ezoom;staticswitcher;
s0_toggle_window_maximized_key = Disabled
[switcher]
s0_focus_on_switch = true
s0_icon_only = true
s0_mipmap = false
[decor]
[commands]
s0_run_command0_key = <Control><Alt>t
s0_command0 = mate-terminal
s0_command1 = mate-panel --run-dialog
s0_run_command1_key = <Alt>F2
s0_command2 = mate-screenshot
s0_run_command2_key = Print
[gnomecompat]
[resize]
s0_mode = 2" > ~/.config/compiz-1/compizconfig/Default.ini
