I did a silly thing. I changed the permissions of my /etc folder using
sudo chmod -R ugo+rw /etc
After that I did some damage control using the command
pkexec chmod 755 /etc
Then I was able to the sudo commands but every time I use a sudo command a warning comes
sudo: /etc/sudoers.d is world writable
Is there a way to completely reset default permissions for /etc ?
Your system is in a very very bad state. Most people would suggest you to either reinstall or to boot into a live CD and then change the permissions of each and every file as it was before.
To get rid of your current error message, you need to change the permission of the /etc/sudoers.d/ directory to 755 and then changing the permissions of the contents of /etc/sudoers.d/ to 440:
sudo chmod 755 /etc/sudoers.d/
sudo chmod 440 /etc/sudoers.d/*
If you have not already change the permission of /etc/sudoers too:
heemayl
  • 93,925
