I am new to Linux distributions, currently working on Ubuntu 14.04. How do you make a live CD from a live installation? Earlier there was "REMASTERSYS".
It seems remastersys is not well supported in latest distribution. I suggest you use systemback. It also has some extra nice features. I have been able to successfully create an iso with it and written it to a 4G memory stick. However it failed to write to a 16G memory stick. I had to use unetbootin for that. My suggestion is to use systemback for creating an iso file and then unetbootin for writing to USB.
- 5,131
- 7
- 33
- 37
Ubuntu Customization Kit, also found through apt-get, or synaptic, and then for added flexibility there is UCK-flow
There are a few extra dependencies you might have to install, but 'uck' and 'uck-flow' are python scripts to help unpack, modify, and repack ISO images.
Edit: I just checked the .deb file for uck-flow it went catatonic on installation. I could easily build it from the source.
Unpack the archive;
sudo python setup.py build
and then
sudo python setup.py install
the executable is located /usr/local/bin/uck-flow, but there is also a menu entry at System Tools (in mine;-)
- 690
