21
When I start my Ubuntu 14.04 LTS machine, the following dialog comes always. If I cancel it and restart, now also it simply comes again and I cannot stop it from coming.
My privacy setting as follows and my system is fully updated.
How can I get rid of this irritating issue?
DUKE
  • 3,388
Try running sudo rm /var/crash/* in a terminal
Answer source
19
If you really want to disable this alert/notification, you need to disable apport which is the crash reporting program of Ubuntu.
apport messages are generated from the logs in /var/crash/, so first try to remove all the files in that directory by sudo rm /var/crash/* and then reboot the computer.
If you want to disable these alerts permanently you need to disable apport. To do so, open the file by sudo vim /etc/default/apport, now change the line enabled=1 to enabled=0.
Although disabling apport is not recommended.
heemayl
  • 93,925
