When I do mvn --v, I get:
Apache Maven 3.0.5
Maven home: /usr/share/maven
Java version: 1.6.0_45, vendor: Sun Microsystems Inc.
Java home: /usr/lib/jvm/java-6-oracle/jre
Default locale: en_IN, platform encoding: UTF-8
OS name: "linux", version: "3.16.0-30-generic", arch: "amd64", family: "unix"
When I do java -version, I get:
java version "1.7.0_76"
Java(TM) SE Runtime Environment (build 1.7.0_76-b13)
Java HotSpot(TM) 64-Bit Server VM (build 24.76-b04, mixed mode)
Now I want maven to use java 7, how do I make this so?
coder005
  • 163
Firstly I opened Ubuntu Software center and searched for jdk removed the installer and default jdk 6 from there. Then I run the command :
sudo update-alternatives --config java
sudo update-alternatives --config javac
And selected the openjdk-7 from there. But when I run :
mvn --v
it said that JAVA_HOME is not set. Then did the following steps:
sudo gedit /etc/bash.bashrc
Added the following lines at the end of the file :
export JAVA_HOME=/usr/lib/jvm/java-7-oracle
export PATH=$PATH:$JAVA_HOME/bin
Then close the gedit. And run the command :
source /etc/bash.bashrc
echo $JAVA_HOME
Path was set. And now :
mvn -v
Apache Maven 3.0.5
Java version: 1.7.0_76, vendor: Oracle Corporation
Java home: /usr/lib/jvm/java-7-oracle/jre
coder005
  • 163
To set the JAVA_HOME variable for only maven you can override your defaults by setting it in your $HOME/.mavenrc file.
The $HOME/.mavenrc is sourced by the mvn script. This is useful if you want to switch jvm for different projects.
This is the content of my $HOME/.mavenrc file:
#export JAVA_HOME=/usr/lib/jvm/java-1.7.0-openjdk-amd64
#export JAVA_HOME=/usr/lib/jvm/java-7-oracle
export JAVA_HOME=/usr/lib/jvm/java-8-oracle
This way i can comment out the jvm i want to use before i run maven.
stalet
  • 589
Here is the documentation on Ubuntu Environment variables.
What we want to do here is persist our JAVA_HOME path.
Most commonly, our java installations go in /usr/lib/jvm. To list the installations present,
ls /usr/lib/jvm
I have /usr/lib/jvm/java-8-openjdk-amd64 among them and that is installation I want to use for maven.
We can add our entry for JAVA_HOME entry to ~/.pam_environment and make it DEFAULT or OVERRIDE - that's your call.
Use whatever text editor you want to open the file (I am using a text editor that is lying around in my system - it's name is xed. You may use gedit or vim or anything)
xed ~/.pam_environment
You will find things like:
Now, let us add a new entry for our JAVA_HOME environment variable. In a new line, enter:
JAVA_HOME   DEFAULT=<your path to your java home location>
or
JAVA_HOME   DEFAULT=${JAVA_HOME}    OVERRIDE=<path to your java home location>
As my java home location is '/usr/lib/jvm/java-8-openjdk-amd64', I am entering JAVA_HOME DEFAULT=${JAVA_HOME} OVERRIDE=/usr/lib/jvm/java-8-openjdk-amd64
Now, log out of your system and log back in for the change to take effect.
Let's check the maven version now.
mvn -version
and it should work : enter image description here
ThunderBird
  • 1,963
  • 13
  • 22
  • 31
