When I try to click on a link on the web page produced by dwww - I get the following error:
Not Found
The requested URL /cgi-bin/dwww/usr/share/doc/ was not found on this server.
Apache/2.4.10 (Ubuntu) Server at randys-laptop Port 80
I've installed the Debian Documentation Browser package.
What am I doing wrong?
muru
  • 207,228
dwww uses cgi to serve the webpages and cgi is no longer enabled in apache2 by default; so you need to enable cgi:
sudo a2enmod cgi
And then restart the apache2 service with:
service apache2 restart
That will solve the major problem you are experiencing with dwww returning not found.
But you might run into another problem. dwww allows access from the web server to files in /var/www/dwww and /usr/share/doc (and it will follow symlinks in other directories to /usr/share/doc).
The additional problem you may find is that some of the documentation files are not in /usr/share/doc.
For example (this will depend on what documentation you have installed), some directories in /usr/share/gtk-doc/html are symlinked to /usr/share/doc/.... These will display is dwww without problem.
But other files are not and will not display automatically. The /usr/share/gtk-doc/html/atk directory, for example, does not use a symlink to /usr/share/doc. Trying to open these files with dwww results in:
dwww will not allow you to read the file /usr/share/gtk-doc/html/atk/index.html
There is probably a solution for this involving apache2/dwww configuration; but I'm no expert in apache2 security and wouldn't want to introduce a problem.
The simple workaround is to use the file:// protocol for those (very) few files where you find this problem.
For the atk documentation example above, the generated url is:
http://<server-name>/cgi-bin/dwww/usr/share/gtk-doc/html/atk/index.html?type=html
You can go up to the address bar and edit it to:
file:///usr/share/gtk-doc/html/atk/index.html?type=html
and the file will then load.
chaskes
  • 15,536
About the dwww will not allow you to read ... issue:
dwww will only show files from paths whitelisted in its DWWW_DOCPATH setting at /etc/dwww/dwww.conf.
The default is /usr/share/doc:/usr/share/info:/usr/share/man:/usr/local/share/doc:/usr/local/share/info:/usr/local/share/man:/usr/share/common-licenses. It does not follow symlinks, so you have to manually add their targets.
MestreLion
  • 20,726
