My system crashed. When I rebooted the disk check reported errors. I asked it to fix the errors. My system will now not boot to login in graphics mode.
After the screen flashes I see
saned disabled
edit /etc/default/saned
The system then stalls. I finally hit Ctrl+Alt+F1 and log in from TTY1. I then see messages:
[96.263452] systemd-logind failed to start unit user@1000.service unknown unit
[96.263892] Failed to start service unknown unit: user@1000.service
The /etc/default/saned file looks OK.
How should I restore the system to allow it to boot completely?
Fabby
  • 35,017
The best you can do right now is:
  1. boot from a LiveCD,
  2. back-up all your data
  3. test whether your drives are OK
    • sudo apt-get install smartmontools
    • sudo smartctl --scan
    • For all devices that come up on the previous command to a sudo smartctl --all /dev/XdY where X and Y are the letters that come up in the previous step
  4. re-install.
    • Replace any drives that show a "fail"
Before you reinstall, have a look here so that this will not happen any more in the future, but that you might just restore a system back-up when something like that happens...
Fabby
  • 35,017
apt-get remove upstart
If it is ubuntu16.04 and you have installed upstart. Worked for me.
Melebius
  • 11,750
