If i have a separate home partition and reinstalled ubuntu will it be safe to delete all config files?
Asked
Active
Viewed 236 times
You can delete files and folders inside ~/.config folder.
This folder generally stores user specific settings. Deleting this folder will not cause any severe harm except it will reset all your preference .
g_p
- 19,034
- 6
- 59
- 69
I would:
- Make a system backup (look here for more info: you're user type 4, I would use CloneZilla )
- Make a data backup (use whatever software you're using now, and make it an unencrypted backup, without password)
- Boot the LiveCD and take the "Try" option
- Delete everything in your current home directory except Pictures, Movies, documents)
- Take the "install" option
- Format the system partition (be careful not to format the wrong one)
- Continue installing normally and take the exact same user name as you had beforehand
