So I had a problem with my server running Ubuntu 14.04 and 3x1T configured with a software RAID. I forced mdadm to mount the RAID with two disks only, I added the missing disk back to the RAID array and the system rebuilt the RAID and everything looked fine..
And now here is the problem. Every time when the server starts I see this messages
[ 2.440341] md0: detected capacity change from 0 to 482848079872
[ 2.460418] md0: unknown partition table
It waits for a couple of seconds and after that it mounts the partitions as it should and everything is fine.
Here is some more info:
mdadm -D /dev/md0 /dev/md0:
Version : 0.90 Creation Time : Sat Feb 26 10:39:28 2011
Raid Level : raid5
Array Size : 1921873792 (1832.84 GiB 1968.00 GB) Used Dev Size : 960936896 (916.42 GiB 984.00 GB) Raid Devices : 3 Total Devices
: 3 Preferred Minor : 0
Persistence : Superblock is persistent
Update Time : Fri Jan 30 19:40:00 2015
State : clean Active Devices : 3 Working Devices : 3 Failed Devices : 0 Spare Devices : 0
Layout : left-symmetric
Chunk Size : 64K
UUID : 91c9bf9f:53a9ecfd:80cbc40e:2f20054f
Events : 0.602824
Number Major Minor RaidDevice State
0 8 1 0 active sync /dev/sda1
1 8 17 1 active sync /dev/sdb1
2 8 33 2 active sync /dev/sdc1
fdisk -l
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes 255 heads, 63
sectors/track, 121601 cylinders, total 1953525168 sectors Units =
sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512
bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00072f13
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 1921875967 960936960 fd Linux raid
autodetect /dev/sda2 1921875968 1953523711 15823872 82
Linux swap / Solaris
Disk /dev/sdb: 1000.2 GB, 1000204886016 bytes 255 heads, 63
Disk identifier: 0x000d8a37
/dev/sdb1 * 2048 1921875967 960936960 fd Linux raid
autodetect /dev/sdb2 1921875968 1953523711 15823872 82
Disk /dev/sdc: 1000.2 GB, 1000204886016 bytes 255 heads, 63
Disk identifier: 0x000e4fef
/dev/sdc1 * 2048 1921875967 960936960 fd Linux raid
autodetect /dev/sdc2 1921875968 1953523711 15823872 82
Disk /dev/md0: 1968.0 GB, 1967998763008 bytes 2 heads, 4
sectors/track, 480468448 cylinders, total 3843747584 sectors Units =
bytes / 512 bytes I/O size (minimum/optimal): 65536 bytes / 131072
bytes Disk identifier: 0x00000000
**Disk /dev/md0 doesn't contain a valid partition table**
Why is it doing this and what can I do to fix it?
