I'm sorry for opening another thread about the Intel Centrino Advanced-N 6235 but after googling I couldn't find an answer. I'm running Ubuntu 14.04 with kernel 3.13 on my laptop. I can't get the bluetooth to run at all, I had windows 7 before this and it worked fine. The wifi works flawlessly out of the box but no matter what I do bluetooth isn't detected. If I go into "software and updates" and click "additional drivers" nothing comes up. If I use the hotkey "fn+f12" nothing comes up either, if I go into the bluetooth option in settings everything is grayed out. Ill provide some logs to help, if you need any others please let me know.
Thank you.
$ lspci | grep Centrino 02:00.0 Network controller: Intel Corporation Centrino Advanced-N 6235 (rev 24)
lsmod | egrep 'iwl|blue' bluetooth 391136 10 bnep,rfcomm iwldvm 232285 0 mac80211 630669 1 iwldvm iwlwifi 169932 1 iwldvm cfg80211 484040 3 iwlwifi,mac80211,iwldvm
dmesg | egrep -i 'iwl|blue [ 4.131864] iwlwifi 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control [ 4.131916] iwlwifi 0000:02:00.0: irq 45 for MSI/MSI-X [ 4.154517] iwlwifi 0000:02:00.0: loaded firmware version 18.168.6.1 op_mode iwldvm [ 4.191584] iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEBUG disabled [ 4.191585] iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEBUGFS enabled [ 4.191586] iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEVICE_TRACING enabled [ 4.191588] iwlwifi 0000:02:00.0: Detected Intel(R) Centrino(R) Advanced-N 6235 AGN, REV=0xB0 [ 4.191653] iwlwifi 0000:02:00.0: L1 Disabled - LTR Disabled [ 4.213127] ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs' [ 4.310786] Bluetooth: Core ver 2.17 [ 4.310804] Bluetooth: HCI device and connection manager initialized [ 4.310811] Bluetooth: HCI socket layer initialized [ 4.310814] Bluetooth: L2CAP socket layer initialized [ 4.310818] Bluetooth: SCO socket layer initialized [ 4.315368] Bluetooth: RFCOMM TTY layer initialized [ 4.315376] Bluetooth: RFCOMM socket layer initialized [ 4.315381] Bluetooth: RFCOMM ver 1.11 [ 4.318228] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 4.318231] Bluetooth: BNEP filters: protocol multicast [ 4.318239] Bluetooth: BNEP socket layer initialized [ 4.513644] iwlwifi 0000:02:00.0: L1 Disabled - LTR Disabled [ 4.520657] iwlwifi 0000:02:00.0: Radio type=0x2-0x1-0x0 [ 4.795151] iwlwifi 0000:02:00.0: L1 Disabled - LTR Disabled [ 4.802175] iwlwifi 0000:02:00.0: Radio type=0x2-0x1-0x0 [ 1082.160208] iwlwifi 0000:02:00.0: RF_KILL bit toggled to disable radio. [ 1082.160368] iwlwifi 0000:02:00.0: Not sending command - RF KILL [ 1082.160411] iwlwifi 0000:02:00.0: Not sending command - RF KILL [ 1082.160539] iwlwifi 0000:02:00.0: Not sending command - RF KILL [ 1082.160547] iwlwifi 0000:02:00.0: Not sending command - RF KILL [ 1082.160554] iwlwifi 0000:02:00.0: Not sending command - RF KILL [ 1082.160562] iwlwifi 0000:02:00.0: Not sending command - RF KILL [ 1082.160573] iwlwifi 0000:02:00.0: Not sending command - RF KILL [ 1082.160642] iwlwifi 0000:02:00.0: Not sending command - RF KILL [ 1082.160820] iwlwifi 0000:02:00.0: Tx flush command to flush out all frames [ 1082.160838] iwlwifi 0000:02:00.0: Tx flush command to flush out all frames [ 1082.160846] iwlwifi 0000:02:00.0: Tx flush command to flush out all frames [ 1082.160850] iwlwifi 0000:02:00.0: Tx flush command to flush out all frames [ 1082.160857] iwlwifi 0000:02:00.0: Tx flush command to flush out all frames [ 1082.160865] iwlwifi 0000:02:00.0: Tx flush command to flush out all frames [ 1082.160869] iwlwifi 0000:02:00.0: Tx flush command to flush out all frames [ 1082.186786] iwlwifi 0000:02:00.0: Not sending command - RF KILL [ 1082.186799] iwlwifi 0000:02:00.0: Not sending command - RF KILL [ 1083.670028] iwlwifi 0000:02:00.0: RF_KILL bit toggled to enable radio. [ 1083.670950] iwlwifi 0000:02:00.0: L1 Disabled - LTR Disabled [ 1083.678041] iwlwifi 0000:02:00.0: Radio type=0x2-0x1-0x0 [ 1086.764310] iwlwifi 0000:02:00.0: RF_KILL bit toggled to disable radio. [ 1086.794657] iwlwifi 0000:02:00.0: Not sending command - RF KILL [ 1086.794665] iwlwifi 0000:02:00.0: Not sending command - RF KILL [ 1097.806343] iwlwifi 0000:02:00.0: RF_KILL bit toggled to enable radio. [ 1097.808673] iwlwifi 0000:02:00.0: L1 Disabled - LTR Disabled [ 1097.815793] iwlwifi 0000:02:00.0: Radio type=0x2-0x1-0x0
