after a few rounds of installs and removes, trying to get Atlas and OpenBLAS to be friend with each other, i have this update-alternatives error, which i think is really a master-slave deadlock, ie. some symlink should to be a slave but is actually a master. Please advise how to fix this.
My setting : ubuntu 12.04
sudo apt-get -f install
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up libatlas3gf-base (3.8.4-3build1) ...
update-alternatives: error: alternative libatlas.so.3gf can't be slave of libblas.so.3gf: it is a master alternative.
dpkg: error processing libatlas3gf-base (--configure):
subprocess installed post-installation script returned error exit status 2
libatlas3gf-base
sudo dpkg --configure -a
libatlas3gf-base
EDIT :
$ update-alternatives --query libblas.so.3gf
update-alternatives: error: no alternatives for libblas.so.3gf.
$ update-alternatives --query libatlas.so.3gf
Link: libatlas.so.3gf
Status: auto
Best: /usr/local/lib/libopenblas.so
Value: none
Alternative: /usr/local/lib/libopenblas.so
Priority: 50
