I have gone through the intial steps and downloaded the files to a USB drive. I have setup my computer to boot to USB. When I try to do install and run the file I'm using the Boot from CD. I restart and it's still not trying to boot to the drive.
I've even tried to just unpack and install to the stick, but it says it doesn't have enough space. The stick is a 64 GB stick.
To boot from a CD or USB drive: Plug in the usb.
Restart your computer and wait for that first screen to pop up.
Often, it'll say something like "Press F12 to Choose Boot Device" somewhere on the screen. ...
Give it a moment to continue booting, and you should see a menu pop up with a list of choices on it.
Select the usb that you installed the .iso file on . It should then begin booting up!
Thanks, hope this helps!
To install Ubuntu from USB stick, try using LiLi, it's easy tool to install Live installer on USB key from .ISO file. Then:
  • boot your PC, open BIOS control center, and change boot order so USB is first OR
  • open boot menu (Typically F12, check google for kay matching your board) and select USB device. Then rest is just pressing enter as you install Ubuntu
Össi
