I had a fully functional vagrant for three months now, but for the last three days, I am getting errors whenever I try to run vagrant up or vagrant reload.
This is the error I get when running vagrant reload
default: Attempting graceful shutdown of VM...
default: Guest communication could not be established! This is usually because
default: SSH is not running, the authentication information was changed,
default: or some other networking issue. Vagrant will force halt, if
default: capable.
default: Forcing shutdown of VM...
default: Clearing any previously set forwarded ports...
default: Clearing any previously set network interfaces...
default: Preparing network interfaces based on configuration...
default: Adapter 1: nat
default: Adapter 2: hostonly
default: Forwarding ports...
default: 80 => 8080 (adapter 1)
default: 22 => 2222 (adapter 1)
default: Running 'pre-boot' VM customizations...
default: Booting VM...
default: Waiting for machine to boot. This may take a few minutes...
default: SSH address: 127.0.0.1:2222
default: SSH username: vagrant
default: SSH auth method: private key
default: Warning: Connection timeout. Retrying...
Timed out while waiting for the machine to boot. This means that
Vagrant was unable to communicate with the guest machine within
the configured ("config.vm.boot_timeout" value) time period.
If you look above, you should be able to see the error(s) that Vagrant had when attempting to connect to the machine. These errors are usually good hints as to what may be wrong.
If you're using a custom box, make sure that networking is properly working and you're able to connect to the machine. It is a common problem that networking isn't setup properly in these boxes. Verify that authentication configurations are also setup properly, as well.
If the box appears to be booting properly, you may want to increase the timeout ("config.vm.boot_timeout") value.
I am using Elementary OS Luna and updated the latest versions of vagrant as well as virtualbox as some answers suggested. But the problems persist.
I have tried most of the popular solutions including enabling the GUI and this. I also tried the solution given here but could not since my virtual box doesn't login.
However, the GUI presented me with this:
 keys: press S to skip mounting or M for manual recovery
I tried both the keys one by one but the problem still remains.
Has anyone had this before who could offer a solution, vagrant isn't widely covered on the web yet and I cant find a reason why this is occurring.
ankita
  • 171
After struggling with all the various options available on different questions, I was still facing the same problem. Finally, I did a
vagrant destroy
followed by
vagrant up
And I have my system working again.
Note: If you too have the habit to directly switch off your computer, you might face this problem soon! In your vagrant terminal (vagrant ssh), always go for a:
sudo shutdown -h now
or you can just type
vagrant halt
after you logout from your ssh.
PS: For those of you who might be afraid to lose your data/code/anything during vagrant destroy, you might relax! I was hesitant using the command, but as per the documentation, all it does is:
This command stops the running machine Vagrant is managing and destroys all resources that were created during the machine creation process. After running this command, your computer should be left at a clean state, as if you never created the guest machine in the first place.
This implies that your code will remain intact, and the next vagrant up would lead you to the same state as you left, only with the problem solved now. :)
ankita
  • 171
