I deleted Python on 14.04, woops! It was 4am and I can't remember why I was doing this. So I re-installed it and all and it works, except for some of that good old virtualenvwrapper.
I've searched all over the internet to figure out what's wrong, I have the correct owners on ~/.cache/pip to jesse:jesse. Does anyone know how I can fix this?
pip
I only have one problem, when I use $ pip I get this error:
The directory '/home/jesse/.cache/pip/http' or its parent directory is not owned
by the current user and the cache has been disabled. Please check the permissions
and owner of that directory. If executing pip with sudo, you may want the -H flag.
.bashrc
Then when I load a terminal or just run $ source ~/.bashrc
/usr/local/bin/python2.7: No module named virtualenvwrapper
virtualenvwrapper.sh: There was a problem running the initialization hooks.
If Python could not import the module virtualenvwrapper.hook_loader,
check that virtualenvwrapper has been installed for
VIRTUALENVWRAPPER_PYTHON=/usr/local/bin/python2.7 and that PATH is
set properly.
Using
  • 14.04 Desktop
  • pip 6.0.6
  • python 2.7.9
Tried
  • Uninstall pip
  • Removing ~/.cache/pip
  • Reinstalling sudo apt-get python-pip
  • Reinstalling easy_install pip
  • Chown on ~/.cache/pip to jesse:jesse
  • Deleting/Removing Python packages a lot, lol.
JREAM
  • 319
I would again purge python-pip and install it differently
 wget https://bootstrap.pypa.io/get-pip.py
Then
 sudo python get-pip.py
And see if that works better for you.
edit
This route will get you newer than what in repo. You can also then update using
 pip install -U pip
Not sure if you can do that if installed with apt-get.
geoffmcc
  • 1,364
