I'm trying to remove libavcodec52 package but it won't work. If I try through Software Central it just tells me it didn't work and to check my internet conection.
If I try it at the terminal, this is what I get
Souljacker Ahab @: ~ $ sudo apt-get remove libavcodec52
Reading package lists ... ready
Building dependency tree
Reading state information ... ready
The following packages were automatically installed and are no longer needed:
libmodplug1 libtwolame0 libva-1-x11-libxcb libxcb-keysyms1 xv0 libcddb2 libass4 libdvbpsi6 libvlc5 libupnp3 libxcb-7-randr0 libiso9660 libkate1 vlc-data
libtar libvlccore4 libvcdinfo0 libebml3 libmpcdec6 libmatroska3 libsdl-image1.2 liba52-0.7.4
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
libavcodec libavformat-extra-extra-52-52 libopenjpeg2 librtmp0
Suggested packages:
libfaad0
The following packages will be REMOVED:
libavcodec52 libavformat52 vlc vlc vlc-nox vlc-plugin-notify-plugin-pulse
The following NEW packages will be installed:
0 upgraded, 4 newly installed, 6 to remove and 1 not upgraded.
You must download kB/5.489 127 kB file.
After this operation, 12.1MB disk space will be freed.
Do you want to continue [Y / n]? s
Err http://br.archive.ubuntu.com/ubuntu/ Natty / universe libopenjpeg2 i386 1.3 + dfsg-4
404 Not Found
Err http://br.archive.ubuntu.com/ubuntu/ Natty / universe librtmp0 i386 2.3-2
404 Not Found
Http://br.archive.ubuntu.com/ubuntu/pool/universe/o/openjpeg/libopenjpeg2_1.3+dfsg-4_i386.deb Failed to fetch 404 Not Found
Http://br.archive.ubuntu.com/ubuntu/pool/universe/r/rtmpdump/librtmp0_2.3-2_i386.deb Failed to fetch 404 Not Found
E: Unable to fetch some archives, maybe run apt-get update or try with - fix-missing?
I've tried an apt-get update and nothing changes.
Any help?
