I've got a new x1 carbon and the track point works as a moving mouse, but the new hardware buttons for right and left click do not function. When I click the left one, the page scrolls up a few lines. When I click the right one, it scrolls down a few lines.
Any hints on how to force the buttons into the right function?
xev lists the left/right buttons as button 4 and 5.
% xinput list-props "TPPS/2 IBM TrackPoint"
Device 'TPPS/2 IBM TrackPoint':
    Device Enabled (136):   1
    Coordinate Transformation Matrix (138): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
    Device Accel Profile (260): 0
    Device Accel Constant Deceleration (261):   1.000000
    Device Accel Adaptive Deceleration (262):   1.000000
    Device Accel Velocity Scaling (263):    10.000000
    Device Product ID (254):    2, 10
    Device Node (255):  "/dev/input/event12"
    Evdev Axis Inversion (304): 0, 0
    Evdev Axes Swap (306):  0
    Axis Labels (307):  "Rel X" (146), "Rel Y" (147)
    Button Labels (308):    "Button Left" (139), "Button Middle" (140), "Button Right" (141), "Button Wheel Up" (142), "Button Wheel Down" (143), "Button Horiz Wheel Left" (144), "Button Horiz Wheel Right" (145)
    Evdev Scrolling Distance (309): 0, 0, 0
    Evdev Middle Button Emulation (310):    1
    Evdev Middle Button Timeout (311):  50
    Evdev Third Button Emulation (312): 0
    Evdev Third Button Emulation Timeout (313): 1000
    Evdev Third Button Emulation Button (314):  3
    Evdev Third Button Emulation Threshold (315):   20
    Evdev Wheel Emulation (316):    1
    Evdev Wheel Emulation Axes (317):   6, 7, 4, 5
    Evdev Wheel Emulation Inertia (318):    10
    Evdev Wheel Emulation Timeout (319):    200
    Evdev Wheel Emulation Button (320): 2
    Evdev Drag Lock Buttons (321):  0
% xinput get-button-map 12 1 2 3 4 5 6 7
I've tried setting all of the button to 1 but that failed to work to enable the proper left-click on the button press.
Thanks for the tips/help.
UPDATE: I turned off the trackpad in the bios and it did not shut off. It worked when I did a boot which surprised me. I then went back into the bios and disabled both the trackpad and the trackpoint and only the trackpoint was disabled. The trackpad still functioned properly.
This led me to think it might be a hardware issue, after getting the run around with lenovo support, who would not work with me without windows running, I booted a windows install usb disk and sure enough the trackpad was disabled.
This seems amazingly odd to me that a setting in the bios is or is not listened to on the OS side, but it might be a hint that there's a need for some sort of new/updated driver in Ubuntu to get this to work out?
Rick
  • 3,727
It's a known bug that has a fix being pushed very soon. https://bugs.freedesktop.org/show_bug.cgi?id=88609
I finally got this working by updating to kernel 3.19 and editing a xorg conf file
Update the kernel using this tutorial:
http://www.linuxandubuntu.com/home/linux-kernel-3-19-stable-released-install-upgrade-in-ubuntu-linux-mint
Then edited /usr/share/X11/xorg.conf.d\11-evdev-trackpoint.conf upated the line:
MatchProduct    "TrackPoint|DualPoint Stick"
to
MatchProduct    "TrackPoint|DualPoint Stick|PS/2 Synaptics TouchPad"
Running Ubuntu 14.04
Calin
  • 705
Add this to /etc/rc.local:
modprobe -r psmouse
modprobe psmouse proto=imps
Then reboot.
muru
  • 207,228
conorsch
  • 121
Everything you need for an X1 Carbon 2015 3rd generation can be found here: Lenovo X1 Carbon 2015 3rd gen 20 BS - trackpoint, clickpad and wifi
Janning
  • 1,967
