When I cd into a directory containing a .exe that I can run in Wine, how do I run that .exe with primusrun?
Specifically, I have installed Skyrim via Steam on PlayOnLinux. I've successfully run other games in Wine, without PlayOnLinux active. But for Skyrim, the game's framerate renders it almost unplayable, even on the lowest settings. I want to run it through primusrun (Bumblebee), so it will use my Nvidia GeForce graphics card instead of the default Intel. Adding primusrun to the command on the shortcut properties allows the game to run using the card, but the game blackscreens after the Bethesda logo, only working properly about 2% of the time.
When I cd into the directory containing TESV.exe, then execute the command primusrun wine TESV.exe in terminal, it just shows a new line as if the command was successfully executed. However, nothing happens to show that that is the case. Nothing launches.
So, to summarize, how do I run Skyrim in Wine from the terminal or via a script, using primusrun to designate my Nvidia graphics card as the one to use? Or else, if this is not possible, can someone link me to some directions on how to fix the blackscreen on launch?
