I need some help to fix some disk space issue. Actually I'm using a private vps cloud server with 50Gb of disk space.
When I run df -h, I get :
Filesystem Size Used Avail Use% Mounted on
/dev/root 48G 45G 570M 99% /
devtmpfs 2.0G 4.0K 2.0G 1% /dev
none 4.0K 0 4.0K 0% /sys/fs/cgroup
none 395M 524K 395M 1% /run
none 5.0M 0 5.0M 0% /run/lock
none 2.0G 0 2.0G 0% /run/shm
none 100M 0 100M 0% /run/user
df -i returns :
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/root 3141600 78065 3063535 3% /
devtmpfs 505084 1438 503646 1% /dev
none 505206 2 505204 1% /sys/fs/cgroup
none 505206 891 504315 1% /run
none 505206 2 505204 1% /run/lock
none 505206 1 505205 1% /run/shm
none 505206 2 505204 1% /run/user
But when I run du -sh / | sort -nr | head, I get :
du: cannot access â/sys/kernel/slab/L2TP/IPv6â: No such file or directory
du: cannot access â/sys/kernel/slab/L2TP/IPâ: No such file or directory
du: cannot access â/proc/391/task/391/fd/4â: No such file or directory
du: cannot access â/proc/391/task/391/fdinfo/4â: No such file or directory
du: cannot access â/proc/391/fd/4â: No such file or directory
du: cannot access â/proc/391/fdinfo/4â: No such file or directory
du: cannot access â/proc/402â: No such file or directory
du: cannot access â/proc/32350â: No such file or directory
du: cannot access â/proc/32354â: No such file or directory
du: cannot access â/proc/32356â: No such file or directory
du: cannot access â/proc/32360â: No such file or directory
du: cannot access â/proc/32363â: No such file or directory
du: cannot access â/proc/32368â: No such file or directory
8.9G /
So I know that both commands don't return the same kind of informations. The first returns the filesystem disk usage, the other, the space used by files.
There is no mounted drive or device, and logs weight is ~167M.
I tried cat /proc/mounts which returns :
rootfs / rootfs rw 0 0
/dev/root / ext4 rw,relatime,errors=remount-ro,data=ordered 0 0
devtmpfs /dev devtmpfs rw,relatime,size=2020336k,nr_inodes=505084,mode=755 0 0
sysfs /sys sysfs rw,relatime 0 0
none /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0
none /proc proc rw,nosuid,nodev,noexec,relatime 0 0
none /proc/sys/fs/binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime 0 0
none /sys/fs/cgroup tmpfs rw,relatime,size=4k,mode=755 0 0
none /sys/fs/fuse/connections fusectl rw,relatime 0 0
none /sys/kernel/security securityfs rw,relatime 0 0
none /run tmpfs rw,nosuid,noexec,relatime,size=404168k,mode=755 0 0
none /sys/fs/pstore pstore rw,relatime 0 0
none /run/lock tmpfs rw,nosuid,nodev,noexec,relatime,size=5120k 0 0
none /run/shm tmpfs rw,nosuid,nodev,relatime 0 0
none /run/user tmpfs rw,nosuid,nodev,noexec,relatime,size=102400k,mode=755 0 0
systemd /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,name=systemd 0 0
So I can I identify what is using so much space, as my du seems ok ?
I tried autoclean and autoremove with no chance, every thing is all right.
BTW I also have a cron which runs datas and mysql dump and send it to Dropbox. But the 7 folders (7 days backup) only use 1.7gb of disk space.
